Tim in D
Hot Rolled
- Mar 11, 2003
- Dallas, Tx
I've been asked to modify some threads in a microscope turret to take a larger size objective lens. This will be my first thread milling exercise on the Haas Minimill. I'm wondering if you can do multiple passes with a single point thread mill. If I G00 to the hole location, Z down, spindle orient and run the threading code will I be able to take another pass if the thread is not quite correct? I plan to set up some test plates with the proper size holes and get everything "dialed in" before I have a go at the real deal. The material is brass. The thread is something like 25mmx .75.
Tim in D
Tim in D
