coulombejerome
- Aug 1, 2014
- Matane, Québec, Canada
Ok ... What are my other options ? I only have a Wear tools offset table avalaible. When i put a value in it, the program stop at the changing tool line (t0808 for example) . Even if it's a smaĺl or big value.
Do you have an idea ? Is there an another place to put tools offset ?
Than you !View attachment 113600
I wouldn't have thought so but maybe your machine is set up to use G50's. The picture in you last post looks like the T or tool tip in your wear offset page In post 3. It is what point of the tool that is programed. Do you have a work shift offset page at the machine?
Brent
I put a G00 in front of my T0808 and it work ! ... The tool change and the value I enter in the Wear Offset Table are good!
So, I have to enter the offset value in the wear offset table and put G00 in front of all my toolchange commands. Is this sound logicial or it's the first time that you see that?
The Geometry Offset Table with no options is weird ... but ... if it work with the wear offset that's good.
Thank you all for your help !!!
With regards to needing the G00, its quite typical but parameter related. Its a parameter I don't visit often with a FS10 control, so I've not committed it to memory. I'll look it up when I get a chance. The other thing you need to be wary of, is that the slides don't move during the Tool Change Operation, if the Tool Offset is called at the same time and without a move command. In this case, the better Format for your program is as follows:
G50 S 3000 T0100 (SELECT THE TOOL WITHOUT OFFSET)
G96 S_ _ _ M03
G00 X_ _ Z_ _ T0101 M08 (APPLY OFFSET DURING MOVE BLOCK)
If the slides don't move during the following command:
G00 T1010
Then you can just select the Tool and Offset as shown immediately above.
Its possible for one of the following "G" codes from Group 1 to be modal:
G00, G01, G02, G03
The G02, and G03 are very much less likely, as you would have had to have stopped a running program during, or immediately after a Circular Interpolation move. Accordingly, it's much more likely that the Modal Group 1 "G" code will be G00, or G01. When the control is initially turned on, G00 will be Modal as the default setting, but it can be changed via parameter.
You would have found that had the Spindle been running, and a Feed Rate specified, that the program would have made it past the Tool Change Operation without the need to specify G00 with the Tool Call. This is a hangover from very early controls, but is a Format I still use and write into CAM Posts. By specifying G00 with the Tool Call command, you're sure of the Group 1 "G" code that is modal.
Regards,
Bill
Notice
