Results 1 to 4 of 4
    anonimasu is offline Aluminum
    Nov 2009
    Sweden(Luleå)
    71
    Default Fanuc 10tf ladder(help figuring out how to actuate the chuck cylinder)
    I have a problem, I am trying to get bar pulling to work on my lathe, however I cant seem to find what M code there is to actuate the chuck, im fairly sure there is a m-Code as there is a secondary branch in the ladder that connects to the same path that the foot pedal has anyone has a clue how to figure out what m code that actuates it.
    Attachment 54548
    Attachment 54547
    x005.6 is the pedal and R004.3 is the connection to the branch higher up that connects to the m code r005.6 is a time delay for closing.
    from what I understand it should be m9 and m19 that triggers thoose signals.
    Sorry about the double thread, I managed to click back and i thought i were in the edit page. if any administrator sees this please delete the other thread.
    Gerrythewelshman is offline Cast Iron
    Oct 2006
    Ireland
    369
    Hi anonimasu,
    The make of machine will probuably determine the codes,Just google the machine to
    get them or just phone the nearest dealer.
    let us know the make.
    Oct 2006
    Ireland
    369
    Hi anonimasu,
    Probuably the make of machine will determine the codes used
    Q. what are you using.
    Just tel. the nearest dealer.
    Nov 2009
    Sweden(Luleå)
    71
    Quote Originally Posted by Gerrythewelshman View Post
    Hi anonimasu,
    it's a mondiale gallic 420 and the dealer has no information except for options parameters on my machine not a pmc data backup or anything.
    (1989's machine)
