Fanuc 11M start rejected
Page 1 of 49 12311 ... LastLast
Results 1 to 20 of 980
    Nov 2016
    593
    118
    75
    Default Fanuc 11M start rejected
    Hello, I have an Acroloc series 1000 cnc 4 axus mill.
    Bought it plauged with problems.
    Worked on it in spare time and was able to get all it's mechanical and alarm codes resolved
    But now simply says start rejected.
    I read through many posts and found one person that had same issue and appears he never fixed or posted he resolved it.
    More likely I bought it!!!
    I have had several mechanics throughout the drama of repairing this dinosour.
    Last tech just had nothing to input.
    Any ideas other than the standard fanuc stuff?
    Jul 2009
    Peoria, IL
    10,794
    38
    8032
    Is it really worth fixing? Even if you get it sorted out, it's still a slow, unreliable, dinosaur, with goofy tool holders.
    I think this is in reference to starting the program. The machine must have an alarm, or the start signal is no being given due to some kind of interlock. If you can find the ladder documents, you might have a chance.
    Have you homed the machine?
    Oct 2005
    Wilmington DE USA
    1,774
    250
    338
    pm sent
    Mike
    Nov 2016
    593
    118
    75
    Here is what Mckenna service said. picture attached, Maybe some one out there can help me to understand this?acroloc.jpg
    Nov 2016
    593
    118
    75
    Default Here is what Mckenna services sent me.
    Jan 2014
    Vancouver, WA. USA
    2,699
    540
    1344
    Based on the schematic, you need to see if you have 24V DC at both sides of the feed hold switch, an air pressure switch, a chip guard safety switch, and at opto coupler 1016. Note where you lose the 24V and the failure point will be between there and the last point you found 24V.
    Jul 2009
    Peoria, IL
    10,794
    38
    8032
    Your machine is stuck in feed hold because of a faulty feed hold switch, open air pressure switch, open chip guard switch, or open lube level switch. Or there is a broken wire in that string.
    You need 24V DC to get from one side of the red line to the other. When that happens, you should be good to go. That's a pretty good schematic. It seems to show the cable and wire numbers, so you should be able to track those things down.
    You can go to the diagnostic page and find line 410 (type 410 and hit cursor down). Bit 5 should be 1. If it is 0, the machine is in feed hold.
    Nov 2016
    593
    118
    75
    Do you know Where the opto coupler is located?
    Jul 2009
    Peoria, IL
    10,794
    38
    8032
    Find the physical spindle lube level switch and see where the wires go. I'm not sure why they used an opto isolator for that switch. It could be on the PCB at the CNC side, or it could be on the actual switch.
    Nov 2016
    593
    118
    75
    We checked the switch and when not depressing it it has 24 volts to both sides when we depress it it breaks the 24 volts and here is a picture of the diagnostic board bit 41020171011_190444.jpg
  11. #11
    Jan 2014
    Vancouver, WA. USA
    2,699
    540
    1344
    Quote Originally Posted by Hot Headz Marine View Post
    Its on some Acroloc board called the MIC.
    Do you have 24V at the connectors shown on the schematic?
  12. #12
    Jul 2009
    Peoria, IL
    10,794
    38
    8032
    In case you don't know, the bits count from 0 to 7 from right to left. So, bit 5 is 3rd from left. It's currently 0.
  13. Likes Motorsports-X liked this post
  14. #13
    Nov 2016
    593
    118
    75
    Thank you. I had been told but did forget.
  15. #14
    Nov 2016
    593
    118
    75
    We checked voltage to the lube pump 24 volt reference and it is going in and out of the loop pump which tells me the float switch is working in the loop up. But we're not getting the lube pump relay to engage so it appears that the problem is on the other side of th20171010_102746.jpge terminal block where the lube pump hooks to
  16. #15
    Nov 2016
    593
    118
    75
    We do have 24 volts going in and out of the lube pump but we do not have lube relay e itngagement. Fuses are good.
    Seems like problem has to be on the other side of the terminal block where the lube pumps hooked to any suggestions
  17. #16
    Nov 2016
    593
    118
    75
    We checked the feed hold switch for power and it was good, we checked the lube pump for 24 volts in and out and it was good, however we do not have voltage to run the loop pump as the relay is not engaging. I believe the problem is on the other side of a terminal block I posted a picture in one of my replies but that's all I know right now.
  18. #17
    Jul 2009
    Peoria, IL
    10,794
    38
    8032
    Try working backwards. Find the C02-2 input on the Fanuc module and trace it back to find the opto.
  19. #18
    Nov 2016
    593
    118
    75
    I lack understanding on that but I do work backwards frequently..lol
  20. Likes Ox liked this post
  21. #19
    Nov 2016
    593
    118
    75
    I've got 24vdc to lube pump and feed hold both sides. I don't have power to lube pump relay and fuses are good.
    I guess I'll have to trace wires from lube pump terminal block back to MIC or Fanuc?
  22. #20
    Nov 2016
    593
    118
    75
    I'd like to scrap it but I just don't have the money to purchase a more modern machine right now..and it sure seems rigid enough, large ball screws and just iverall beefy..and seems simple but clearly not.
