Okay so I program several different Fanuc routers and I occasionally have an issue with some of the older 15M controllers cutting full circles when they should only be cutting a small arc when tool radius comp (G41/G42)is applied. The same move with a G40 and it will cut the small arc just as it should. A G41 or G42 with even a zero in the offset value and it glitch.
This doesn't happen with every program I send but I will send dozens of different programs in a single day. I don't have time to run a dry cycle before every job.
And yes I have tried using I and J instead of R.
Is this a common issue with older controllers or is there something other than not using tool comp to ensure this won't happen?
