Hello all,
Recently replaced the spindle board on my Kitamura MCenter 2 with Fanuc 6m-b. Prior the machine would function, but freeze at a spindle speed command in the program - no alarms, "FWD" button on the NC was illuminated as if the spindle was turning. Replaced the top board and now I get the #4 LED illuminated (over load). The alarm page on the NC doesn't show a typical alarm, machine will jog, zero return, tool magazine responds to input, but since the machine is alarming I cannot do any MDI to even test the spindle.
I have the repair manual and set all the jumpers accordingly, but there are not specifics about over load (or reading just fails me).
I have proper low voltages at all the pins on the spindle board, and if I disconnect "CN5" the light goes away if that helps.
Any suggestions?
-J
Any suggestions?
-J
