Bob E
Hot Rolled
- Sep 25, 2006
- Middletown, PA
1981 Kitamura Mycenter 2
FANUC 6MB
FANUC DC Model 5 servos
I was having some noise in the Y-axis and assumed it was a thrust bearing issue.
Replaced them and had the same noise.
Pulled the servo back off and ran it unattached and it seemed like alot of brush noise.
Pulled the brushes, blew out alot of carbon dust (I do this every 6-12 mos. and have seen more carbon dust the last several times)
Put new brushes in and was much quieter spinning by hand.
Reassemble, power up and now get SERVO 401 and the TGLS (Tach Gen. Lost Signal) led is lit on drive.
Google google google.... I pull the end cap off the servo to check pulse coder and I find ALOT of the carbon dust had made it into the end cap and settled right on the back side of the cannon plug for the pulse coder.
I blew all this out. Washed down with contact cleaner and blew it dry.
Checked inside the pulse coder and that was clean.
Reassemble...same error.
Disassemble.....pull the end bell off the servo and scrub all the carbon dust off inside. Polished the commutator by hand while in the motor. Scrape between the comm. bars until clean.
Reassemble....same error.
Swap the X and Y servos and the error follows the servo.
So suspected either the wiring from inside the end cap cannon plug to the coder or the coder itself to be faulty.
The cannon plug to coder board continuity checked out fine but that's with the wiring in entirely different positions from the assembled state.
I got a couple used pulse coders off internet (parted out from working machines...but who knows)
Spent over 4 hours resoldering cannon plug pins to completely replace the harness and pulse coder.
Could the servo motor itself be causing this error??
There are only a few servos on ebay that are 108 volt and 2000 pulse coder like mine...but I guess the next step is to roll the dice on one of them.
I just love replacing my 35 year old electrical parts with someone else's 35 year old electrical parts.
This machine still runs 1 or 2 jobs very well and pays its way....it's just these endless weekends of troubleshooting that gets it closer to the door.
Thanks for reading.
FANUC 6MB
Thanks for reading.
