twr
Hot Rolled
- Mar 18, 2014
- Kitchener Ont. Canada
Hi the problem i am having is with a 1983 Mori Seiki lathe Fanuc 6TB: I can't receive a program from the computer to the fanuc control and the EDIT at the bottom of the screen just flashes. When sending a program to the control, with the key lock turn off. I type the program number push the read button on the control it dims some of the leds on the RS232 tester for a second but no RTS or CTS led lights come on. I can send a program from the machine to the computer and the led lights RTS and CTS both come on when sending. I am using a cable that was tested on my mill fanuc Om and it works fine. I am in EDIT mode and the program lock key is turned off. I have the chuck closed and chuck key is set to inside and seems to work because if chuck is open the spindle will not run. I checked this in case its a interlock of some sort. I also went into Diagnostic and i can see a number change when i push the READ button. I am using Cimco edit to send and receive. I must have a parameter or a setting wrong or RS 232 chip any ideas that could help?
