markp
Hot Rolled
- Oct 7, 2006
- Petaluma CA 94952
Ive got a Mitsui surface grinder with a Fanuc A06B-6058-H221 Servo Amp for X and Y. Fanuc OM controller. It has sometimes had a minor problem starting the amp for years. Sometimes the large 3 phase relay on the amplifier transistor board will drop out on start up (HC high current alarm). Often only in X, sometimes in X and Y. After a restart it used to go away. Does not alarm out when in use (after it starts).
This has gotten worse recently. Now it takes several restarts (or flipping the breaker on the amp) to get it going. Still stays on after a successful start, at least for several hours at a time that Ive used it lately. I do have a service manual, see some reference to setting the parameters to reduce the inrush current. Are these settable from the control? I looked at the parameters in the control but didnt see anything corresponding to the numbers given in the manual.
Maybe the amp is just going bad?
