Had two identical power failures on our FANUC 18M-controlled Quantum Q-1000V mill. Both failures occurred while in cycle on the same tool immediately after the tool change. Machine completely shut off at control box and the loud spindle fan also shut off, spindle continued to rotate under momentum until coming to a gradual stop. Neither the breaker on the machine nor the breaker on the wall tripped. Machine could not be restarted with the "ON" button, turning machine breaker off and on did nothing either. Turning off and on the wall breaker allowed the machine to be restarted. Alarms 350, 351, 414 and 749 present upon restart. Machine is currently functioning, not sure for how long. Any ideas on where to start?
