I have a Daewoo Puma 6 with Fanuc10FT symbolic FAPT. I am trying to make a simple part with the FAPT system and I am not for sure were you input the work coordinates into the FAPT questions. In the examples that I have from the book the home position, index position, and the machining start point are all suppose to have the same coordinates. This does not make since to me because that is not where my part is relative to the machines coordinates. And the machine does not move to my part. I have also used the face of my part on the z axis as the machining start point and the machine moves past the face closer to the chuck. Am I messing up when programming with the FAPT or is something else not set up right? Thanks for any help.
