Hi Guys,
I was wondering if on an older fanuc control like 15B which has a PCMCIA slot on the CPU, if you can use your normal flash type PCMCIA cards rather than the older SRAM cards which cost a packet and require a battery in them.
In the newer i series controls which have the PCMCIA slot next to the LCD, i have used normal flash type cards in without any problems, but because they are completely different architechture inside didn't know if those cards would work in older systems.
Any ideas / expoeriences ?
Cheers
Cheers
