Fanuc OT, feedrate missing, but its not!
Results 1 to 8 of 8
    Dec 2006
    Central Ky
    1,060
    50
    78
    Default Fanuc OT, feedrate missing, but its not!
    Well, after 20 years it looks like I need a lesson in Programming 101. Starting a program with a facing cut, IF it is the first time I push cycle start, it runs fine. After that, I am getting the "O11 P/S" alarm, indicating that there is no feedrate. Please, look at my program, and tell me what I am missing. Cause I see a feedrate, but the control is not for some reason. And, keep in mind, that the other 2 programs that I have run on this lathe are programmed the same and I had no trouble at all. So, I must be missing something.
    Here is my code:
    O3333
    N1 G50 S2500
    G00 T0101
    G40
    G96 S0500 M03
    X0.8 Z0.0 (machine positions here, then alarms)
    G01 X-.064 F0.006
    Z0.02
    G00 X.591
    etc......
    Feb 2006
    Republic of Texas
    2,223
    I don't see anything to cause the error.
    Curious to why you have the G00 3 blocks from first move.
    Dec 2006
    Central Ky
    1,060
    50
    78
    habit, always programmed that way.
    So, it just goes to show, you want to figure out something simple, post it here first! I am bar pulling at teh end, using G98, and on this control, unlike my 10T, I MUST put in a G99 to get it back into feed per revolution.
    Im ready for my dunce cap now.
    Oct 2007
    Watertown, SD
    246
    Are you using a G98 further down in the program? It may be looking at IPM rather than IPR in which case your feedrate would be too slow for the control to handle. I would try this:
    G99G1XZF.006
    Good luck!
    I see you beat me to the punch!!
    Last edited by hdrider63; 09-01-2010 at 07:01 AM. Reason: Posted just after he figgered it out.
    Aug 2002
    West Unity, Ohio
    22,877
    3256
    6272
    Quote Originally Posted by spock View Post
    I find that any time my machine doesn't like to "re-start" properly in AUTO cycle - it always comes back to how I left it at the end of the prog. Not how I started it.
    Think Snow Eh!
    Ox
    Jul 2006
    Arizona
    4,395
    17741
    4105
    Here is my code:
    O3333
    N1 G50 S2500
    G00 T0101
    G40
    G96 S0500 M03
    G00 X0.8 Z0.0 (machine positions here, then alarms)
    G01 X-.064 F0.006
    Z0.02
    G00 X.591
    etc......
    I would add the G00 command. It should be modal from the T0101 line but I do not see an X or Z move there so it may be the issue.
    Jun 2007
    Easton, PA
    482
    14
    One way to avoid such problems is to have a subprogram containing default settings (or whatever else you like) called at the beginning of each operation similar to the Hardinge Safe Index programs.
    My first command (when not setting a workshift) is M91. This calls up program 9001 which has commands such as G0G40G99G97G80, etc.
    Not only saves typing in the main program, but eliminates senior moments.
    Oct 2006
    Ireland
    430
    29
    72
    Default feed
    Hi,
    Just a thought . If the machine is reading G21 metric by 'mistake' it might not read 0.006mm (0.0002") and fault out.
