Hey QB
Curiously quiet here.
While I'm in no way an expert on the miserable thing, here are a few things.
Pinout of the RS232 cable:
Machine 25 pin: PC 25 pin:
1------------------------1
2------------------------3
3------------------------2
4----| |---4
5----| |---5
7------------------------7
6----| |---6
8----| |---8
20---| |---20
This means pins 4-5 and 6-8-20 respectively is tied together on both sides, but do not connect from end to end.
If you only have 1 machine, get the free version of NcNet-Lite.
Set the RS232 parameters on both sides to be the same, that info should be on your parametrers CD from Fanuck.
Start NcNet-Lite, select the program you want to send, stand on one foot and with thumb in mouth press the send button.
Go to the machine, Edit---Program---RIGHT->---Read---Exec.
If you said your daily prayers, the program should appear sometime soon.
As a sidenote, If you had a Haas, the sequence would be Select prog --> send on the PC
RECVRS232 on the machine.
And that in no particular order.
Question: Do you have the CF reader on your Robodrill? If you do then go to Staples and get a CF to PCMCIA adapter, a 256MB CF card and a USB reader for your PC. May run you somewhere $60 total. It works OK, but you have to remember that the filename should match the program name.
IOW
O0100 -- Filename
should begin with:
O0100 (Blah blah)
M30
Good luck! ( You gonna need it)
