toolsteel
Titanium
- Nov 9, 2012
- NW Wisconsin (BFE)
I have machined very few parts in a 4th axis on a vertical mill....even fewer with a tailstock holding one end. It seems that if the tailstock is not directly in line with the indexer I get the same results as if I were turning a taper in a manual lathe by offsetting the tailstock. I am machining a round part square in the indexer with a face mill addressing the top of the part. When I make the first cut it is perfectly level to the table. When I index 180 degrees that surface now has .002" of runout.......in my head (here we go) it is because I machined parellel to my table.....but.....when I indexed the part, I did so around an axis that is not parellel to my table????? Have I overly confused the issue???? In a nutshell......I am thinking....the axis between the tailstock/center needs to be perfectly aligned with the indexer/collet. What then of the center I am drilling in the part?......Will drilling my center off-center affect the end result? I am thinking it will not affect it.......I am gonna find out soon enough....just wondering what insight the people who do this on a regular basis may have.
