triumph406
- Sep 14, 2008
- ca
I have a recently acquired Royal Filtermist F-1200.
In maybe 100+hours of running it’s collected at best ½ cup of coolant.
The only time it worked to collect coolant was when a ½ drill got coverd in swarf, and
turned the coolant to mist inside the machine. That happened once.
I have tried to replicate that condition unsuccessfully. I have let the machine run with a drill
covered in swarf, with coolant spraying on it for 15-20 minutes, the outlet hose is dry,
no captured coolant.
If I spray coolant at the inlet it will pull the coolant into the unit, and expel it out thru the spigot outlet. That suggests that coolant channel around in the interior isn't blocked.
It appears to have new foam pads inside the drum, their clean no debris or heavy deposits.
The way their die-cut suggests their correct for the drum. The foam inserts that go into the exhaust outlets appear to be new as well.
The seal at the bottom is good, and doesn’t leak.
I talked to support at Royal, they suggested try removing the drum foam inserts, tried that, no effect, just got noisier.
I get approx. 6A on each leg of the 208V supply, the nameplate says 7.5A so I’m in the ball park.
Rotation is in the correct direction.
The unit is mounted in the top far right hand corner of a Fadal 4020. I’ve coverd the top opening of the machine opening with Lexan plates that I had left over. The gap between the head and the ATC isn’t coverd, so there’s still plenty of area for the air to get in.
I’ve even had an 8 8” hose going down to the area of the drill, that didn’t work.
I can see the heavy droplets thrown out by the spinning toll not being captured, but the mist doesn’t seem to be captured, if it was it would be expelled out of the spigot.
What have other peoples experiences been with the older Royal F-1200? I've read mixed reviews, but not sure if I've seen one where somebody had said it plain didn't work.
Even having the hose down at the level of the tool didn't seem to help (only temporary)
Sorry about that picture, turn your head 90 deg CW for correct orientation
Last resort is to get get some smooth bore tubing, and run the inlet inside the machine close to the head. That's $60 of tubing I don't want to spend if it's not going to work
