holows88
- Aug 6, 2014
- Mid-Michigan, USA
Hello all,
I'm still relatively new to programming on our Mazak QT lathes w/Mazatrol.
I'm hoping someone can give me some sort of recommendation on how to improve the surface finish on a groove in a part we're making. Here's what it's programmed to currently:
Cut-Off/Grooving tool: SGIH 26-3 with GTN3 IC328 insert (.123 wide)
Feed: .0005
DOC: .01
RV/FV: 788 (Default for aluminum on our controller)
I broke a blade using these settings, so I'm very wary of being too aggressive:
Feed: .0080
DOC: .01
RV/FV: 788
The cut is giving me a very raggedy edge. The blade is straight, the height is dead nuts. Does anyone have any advice?
Thanks in advance!
Feed: .0005
DOC: .01
Feed: .0080
DOC: .01
RV/FV: 788
Thanks in advance!
