wolfgang073
- Sep 27, 2013
- Moscow
Hi everybody.
There are two new machining center under control iTNC620 there.
The first center works without fails. But probably there was disabled the function, so-called "tool checking at carousel's pocket". I have checked that operation. The carousel turned to right position (e.g. pocket is empty), the spindel moved to carousels pocket, sat down, moved up, and went back without tool. If the carousel's pocket is not empty the tool changing goes on without fails.
So I would like tell about second center.
This time the customer can not work with that center bacause tool change function doesn't work.
The problem description:
The carousel turns to right position (e.g. pocket 4), the spindle moves to carousels's pocket, sit down onto tool and immediately "goes to sleep".There are no moves there.
I have checked tool changer wiring and its signals. It is OK.
I think there is a software problem or parameters there.
So I am interesting what *.PLC program determines work of TC (tool changer)?
Thanks.
Thanks.
