First try on D2 62Rc(video)
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
    Feb 2011
    Grant Alabama USA
    602
    168
    214
    Default First try on D2 62Rc(video)
    In an effort to perfect our speeds and feeds while hardmilling, this is the first try. Its not right yet, but far from a failure. I apologize for the language at the end, but I do not edit my videos. The endmill was a reground garr VRX at .353 diameter. Parameters were 750 sfm, .018 radial, .300 axial and .004 ipt.
    The next run will be at 650 sfm, .006 ipt using a mist sprayer. Also, any small areas will be blocked off to be ran at lower speeds to allow cooling time for the cutter. Just a note for anyone using a Mag Fadal, The E-stop button is not quick enough, use feed hold. The endmill was badly worn on the corners, but not broken, and will be resharpened and used again.
    Hsm on heat treated D2 - YouTube
  2. Likes jdj, solidworkscadman liked this post
  3. #2
    Feb 2003
    Illinois
    4,763
    3756
    1480
    Nice vid!
    Your Fadal seems to move pretty good. Is it a FX with Fanuc control?
  4. Likes jdj liked this post
  5. #3
    Jul 2013
    Indianapolis
    62
    9
    Default Re: First try on D2 62Rc(video)
    Why not use a ceramic insert cutter?
  6. #4
    Jun 2006
    Near Seattle
    4,296
    2285
    1032
    A general question (maybe there's a good thread on this somewhere) - how to decide where flood coolant is and is not a good idea? Is air blast always suitable when flood coolant is not?
    It would be nice to see a closeup of the resulting part, if allowed.
  7. Likes jdj liked this post
  8. #5
    Feb 2012
    1,150
    774
    1211
    Quote Originally Posted by bryan_machine View Post
    When milling low carbon or annealed alloy steel, the flood coolant threshold is typically around 300 SFM on an inserted cutter. That's when the cutting edge gets too hot and thermal shock from flood coolant can damage the cutting edge. This threshold lowers as the cutting edge dulls. The threshold can also change significantly depending on material hardness and cutter geometry, so it's best to gage cutting zone temperature by chip color. When chips start changing color from silver to bronze, it's time to turn off the coolant. When chips are blue/purple, it's just about guaranteed that flood coolant will damage the carbide.
    Fresh, solid carbide endmills with HSM toolpaths can cut much faster than 300SFM without generating much heat, but most folks will crank up the speed and turn off the coolant anyway. High feed mills also generate less heat.
    Air blast is optional. Its primary purpose is clear chips to prevent recutting. During long, dry cycles, air blast can also significantly cool the toolholder body. We machine hardened materials on a regular basis and air blast will keep the toolholders around 100 degrees F, compared to 150+ without the air blast. Good for the spindle and good for holding tolerance. Makes no difference to cutter life, however.
    -Sol
  9. Likes John Welden, Nick Mueller, Hertz, Bobw liked this post
  10. #6
    Feb 2011
    Grant Alabama USA
    602
    168
    214
    I agree with Orange vise up until the part about air blast not helping cutter life. Maybe tis is due to how fast we generally run. The coating on the endmills used in my videos is heat tolerant, not heat activated, so any temp drop is welcomed. Even the fan effect of the cutter spinning at high rpm helps. A mist sprayer used with the cutter in this video may only lower the running temp by a hundred or so degrees, but that will allow extended engagement time without overheating. This also helps with TiAln coatings.
  11. Likes jdj liked this post
  12. #7
    Mar 2004
    Waukesha, WI
    7,484
    700
    1814
    I gotta ask, even though this is a rookie question when it comes to high speed machining like this. If the material is heat treated D2, are these standard off the shelf endmills you use for something like this? Is it a special type of carbide that allows this much sparking off the cutter? Is it the coating, tool grind geometry?
    And if heat treated tool steels can be cut at this type of feed and speed, then can't soft cold roll steel be cut even faster? Frankly, I've seen this before but never attempt to try this type of cutting myself unless I'm on aluminum.
    I too, would have liked to have seen the finished product of that run.
  13. #8
    Feb 2011
    Grant Alabama USA
    602
    168
    214
    Quote Originally Posted by Dave K View Post
    The basic endmill is common, just C4 carbide. The grind and coating is what makes the difference. Othe materials are machined like this on a regular basis, only larger cuts and faster. It will be two weeks befofe I get back to where I left the block, but it was ( D 2) machined in block letters. It did not finish the inside of the D because of my programming error. I'm not sure the endmill could have entered the cut, the corners were in bad shape. I am working on this because ceramic cutters arent always the best way to machine intricate details.
  14. Likes jdj liked this post
  15. #9
    Jun 2012
    Michigan
    8,320
    2473
    2773
    Sure beats grinding.
    How many parts (estimate) with one end mill?
    Buck
  16. #10
    Feb 2012
    CANADA
    Ontario
    1,094
    83
    410
    Quote Originally Posted by michiganbuck View Post
    Buck
    Lol, one!
    Seriously though I bet if you reduce the speed a bit it could help with tool life a lot.
    For hard stuff like that AlTin nano-coating works pretty good.
    Imo when I see sparks it generally means "slow down"
    I have machined 60rc D2 before at half the speed and no sparks.
    Not sure how it would affect the cutter life though -only ran for 2minutes or so.
  17. #11
    Feb 2011
    Grant Alabama USA
    602
    168
    214
    Buck
    I am trying to get 15 minutes actual "in cut time" at this speed, or as Zero said, twice as long at 50% of what I was doing here. Also in his post he said 2 minutes, this had around 6 without breaking. A 1/2" would have done better in this situation because of its thicker core absorbing the heat slower. As mentioned, it beats grinding. This regrind cost $17.22 delivered. I will have this worked out before the end of the year. The next run will have a koolmist sprayer and just a bit less sfm, higher feed. I will probably use a 1/2" also.
  18. #12
    Jan 2007
    Flushing/Flint, Michigan
    6,181
    246
    5004
    Quote Originally Posted by jamesu229 View Post
    The basic endmill is common, just C4 carbide. .
    C4???
    Are you sure?
    Who the heck is making C4 rod for end mills and why would you run c-4 on hard D-2?
    Bob
  19. #13
    Apr 2011
    NJ, USA
    454
    98
    101
    What kind of thought process goes into grinding a cutting tool like this? Do you start with a standard set of angles and reliefs and then make adjustments from there?
    If so, what factors would allow you better tool life, or faster cutting speeds?
    Im sure its heavily dependent on what material is being cut, but maybe there are some generalizations?
  20. #14
    Feb 2012
    CANADA
    Ontario
    1,094
    83
    410
    We often machine 50-55RC tool steel dry.
    At 150 SFM we get 1 hour of tool life slotting.
    In your HSM application i bet 10$ your tool will survive for at least an hour at 350 SFM
    We don't bother with regrinds so our target is usually at least an hour.
  21. Likes 5 axis Fidia guy liked this post
  22. #15
    Oct 2007
    detroit,mich.
    4,707
    4710
    413
    Quote Originally Posted by zero_divide View Post
    When you get to machining 58Rc and over, hard steel, at higher speeds, the small chips incinerate in the air. It isn't QUITE the same type of spark as if a dull tool was cutting/rubbing. When turning hardened steel, it sometimes appears that a fountain of fire is coming off the tool/part interface. D.O.C. plays a big part (among other things!) in these unusual situations.
  23. Likes Oldwrench liked this post
  24. #16
    Feb 2011
    Grant Alabama USA
    602
    168
    214
    Heres a picture of the part. I have made the needed modifications to the endmill and tool path that should give the results I'm looking for. The new parameters are 650 sfm , .015 radial and .010 ipt. All small areas are blocked off, and will be machined at the end of the program using 350 sfm at .015 z steps at .004 ipt. The customer that asked me do develop this cutter/path was very pleased with the initial results and will be using them quite often after a successful run.
  25. Likes Ray Behner, jdj, bryan_machine liked this post
  26. #17
    Feb 2012
    CANADA
    Ontario
    1,094
    83
    410
    0.01 ipt!
    Wow 0.004 ipt for slotting seems like alot.
    Do you have some sort of radius on the corners?
    Becase i dont see how it will not chip.
  27. #18
    Feb 2011
    Grant Alabama USA
    602
    168
    214
    .004 ipt should be no problem. The end grind I chose is basically a modified feed mill. I understand 30Rc is very different, but using a 3/4 endmill with my normal grind, I can face at .015 deep, 7500 rpm and 175 ipm, reliably. The new end grind is much tougher. I have 3 prototype cutters and plenty of material to play with. DLC coating with a protective outer coating is also an option, as $75 is the customers upper limit for a 1/2 that will run at the rates we are looking at. The endmill in the video was under $20, and I want to keep the cost low like this, better for business.
  28. Likes jdj liked this post
  29. #19
    Mar 2004
    Waukesha, WI
    7,484
    700
    1814
    Am I reading this correctly? That's about a 1470 SFM. With a normal ground endmill, this is the speed you run on D2?
  30. #20
    Oct 2007
    detroit,mich.
    4,707
    4710
    413
    Soft D2 isn't as bad as some people make it out to be. You have a point however! That is pretty damn fast. I am guessing that the grind is Jamesu229's, NOT regular. The low D.O.C. also helps.
