earth2joel
- Nov 23, 2014
- Fort Wayne, IN USA
I have a Cincinnati-Lamb 750 VMC. I keep getting a lube air pressure alarm (1066). I've replaced the proximity sensors, which were suspect. I have low pressure readings in the cube shaped sensors, but there is no sense to their readings. They will read fine then just drop to 1-3 pounds and refuse to reset, even if I cycle the machine on and off.
If anyone has experience with these, help would be appreciated.
