Tuff Luck Tom
- Feb 14, 2010
- Asheville, Nc, Usa
Ok for some reason I just can't remember what coolants we ran at any of the shops I've been at. Probably because there was so much other stuff I was focused on. I am finally adding more CNC capabilities to my personal shop. The latest acquisition is a dinosaur of a Lathe. It is a Hitachi Seiki 3ne-300 with Fanuc 5t controls. While it is a far throw from the Haas VL2s, Okumas, Mori Seikis, and Daewoos I have spent time with it is in good shape for its age and even has a behind the tape reader to interface with a pc.
So here it is I'll be running mostly brass, aluminum and some stainless. At this time I run very little steel. But the product line may evolve with the ability to better run production. The shops I was at always ran water soluble coolants. I never noticed any weird film inside the machine or film in the sump. We also never had a problem with bacteria but often machines would need to be topped off and seldom if ever replaced the coolant. I'm guessing coolant life was never a problem due to having to top off the machines often due to evap and loss in the chip bucket. We always had a brix scope to keep track of the mixture. So that's where I am at and what I am used to. I understand I will likely have bacteria issues in my little shop or some other compromise. I don't mind buying a good coolant I just don't want to buy junk and go about the trial and error method.
I am looking at Trim, Valcool, and Oak products right now. Any insights? And thanks in advance!
