converterking
Stainless
- Apr 17, 2004
- Kolding Denmark
Does anyone have a copy of the bellhousing bolt pattern for a 7.3 Ford diesel engine?
This is close if not spot on. A few years late is better than never.
Do you have the correct infomation somewhere? I'm trying to make an adapter plate for a rear gear engine so they're not commercially availableHow did you come up with those numbers?
Your X and Y are reversed.
All your Navistar dimensions are rounded to the nearest 1/8th of millimeter. I only checked the dowel pin locations and both are off by nearly 1/2 a mm. That pattern was designed by IH in 1980 long before anything IH was metric.
Your starter is clocked wrong. I know what starter that's for and it will fit that way, but it is a very bad clocking.
The starter bore is wrong as well. 76.1mm is too small.
The profile of your adapter isn't even close to the required shape.
Hey, atleast your Cummins dimensions are correct.
Yes they are.Do you have the correct infomation somewhere? I'm trying to make an adapter plate for a rear gear engine so they're not commercially available
Sorry should clarify, not in australiaYes they are.
Notice
