Ukraine Train
Cast Iron
- Feb 10, 2014
- Ohio
I recently purchased a 1986 Mazak lathe. It had a bad spindle motor cooling fan, which was replaced, and it seemed to run fine after that. It sat for about a week and then as soon as I turned on the main switch, two of the glass fuses blew that are on the spindle board. The controller fans and motor fan run off these fuses, as well as other stuff on the board. I tried disconnecting all the fans and the fuses still blow, so it seems like the problem is somewhere in the controller itself. Any suggestions on how to diagnose this? It's a Mitsubishi FR-SE-2-22k controller. The alarm on the screen is 205 motor overload. The hydraulics do not kick on.
