Poofius
- Dec 11, 2014
- Pennsylvania, USA
Hello, looking for insight on the following. When taper threading with G32, does the feed rate vary from the pitch of the thread? For example, I am programming a screw with a 1.5mm(.0591") pitch thread. The tip of these screws are pointed and the thread follows this pointed tip then continues straight on the OD. My code that is being posted gives a different feed rate for the tapered portion than it does for the straight. It doesn't vary much, maybe .0015" difference at most. I have run the threading cycle leaving the different feed rates in there and also changing them to be the same. I am having a hard time seeing any difference in the threads.
I have made plenty of bone screws with tapered to straight threads but this question has always come up.
