DMF_TomB
- Dec 13, 2008
- Rochester, NY, USA
i use a CNC gantry mill with vertical and horizontal head so when G43 used normally it is
G0 G43 H1 Z20.
instead of
G0 G43 H1 X0. Y0. Z20.
..... as if multiple axis in line the length comp will effect every axis in line. on a cnc where it can point to +X or -X, +Y or -Y or -Z the cnc does not know which axis G43 should effect. but on 3 horizontal cnc's i use nearby if more than one axis in line G43 only effects Z
is it more normal in gcode if more than one axis in gcode line where G43 used length comp only effects Z ?? can others have
G0 G43 H1 X0. Y0. Z20. and length comp only effects Z ??
maybe it is a parameter setting ? i was told it is safer to use
G0 X0. Y0.
G0 G43 H1 Z20.
or only one axis in line where G43 used. i am just wondering maybe only important on 5 axis machine or only a few CNC
G0 G43 H1 Z20.
instead of
G0 X0. Y0.
G0 G43 H1 Z20.
