G43 and more than one axis in line - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21
    Jan 2015
    503
    80
    257
    Quote Originally Posted by DMF_TomB View Post
    G43 AND G44 is used on any axis. G43 or G44 depends on if pointing at -X or +X same with Y. about only direction fixed is Z pointing toward -Z
    If you always use negative tool lengths, sure. With a probe or tool setter using positive lengths, that's not the case. The spindle offset is positive. Put a G49 on a line by itself and watch your spindle squash the tool into part/vise/table when it moves down.
  2. #22
    Jan 2015
    503
    80
    257
    Quote Originally Posted by DavidScott View Post
    This does not always work, depends on the control, and parameters as I am finding out. It can be handy if your control doesn't have fixture offsets, like a Fanuc 3.
    Does that work on Haas?
  3. #23
    Dec 2008
    New York
    8,389
    2243
    Quote Originally Posted by thesidetalker View Post
    always more - comp will cut deeper and more + will cut less on most machines
    i have used a Mazak mill that was backwards or more + on length comp cut more. yet mazak lathe next to it was normal more - cuts more......... most likely a parameter setting
    G43 and G44 if tool is -.500 length comp the G43 or G44 will control which direction comp goes depends on which direction spindle pointing. i always remember
    if spindle points to negative direction use G43
    if spindle points to positive direction use G44
    since in Z normally spindle only points toward negative only G43 is just normally used with Z axis
    but with a parameter setting change probably anything is possible and any machine can act differently
  4. #24
    May 2006
    Burlington, North Carolina
    254
    209
    100
    Our Daewoo with a Fanuc 21i will work either way. I just always got in the habit of doing
    G0 X Y
    G43 H Z0.1
    In case there were clamps in the way and what-not.
  5. #25
    Dec 2008
    New York
    8,389
    2243
    Check out parameter 6000 bit 4 in your manual. I think you will see this is where the ability to have the G43 only affect Z or affect any named axis is determined.
    yes that screen says cutter comp and line has 0 and 1's like
    00010001
    no way i would change it as machine runs ok for decades. but nice to know it can be changed. now if talking about it to other machinist and they disagree on only 1 axis in G43 line than i can mentioned it can be changed by parameters
  6. #26
    Dec 2008
    New York
    8,389
    2243
    my machines use wear comp
    if a tool has max length of 10" gage length and comp of -.500 cause it is 9.5000 GL the programming uses the 10" length. if G49 or no length comp in effect it stays farther away as tool is always shorter than max length used for programming
    wear comp only, often is used in normal comp columns on cnc
    main reason is it prevents crashes of no G43 is in effect or rather tool is farther away. i have seen a (tap) drill, drill hole shallow, then next tool a tap hit bottom of hole. thats a rare case where wear comp still can cause a problem
  7. #27
    Jan 2014
    Washington
    2,986
    576
    1498
    00010001
    Changing 00010001 to 00000001 will make G43 effective only in Z regardless of other axes called on the G43 line.
    For a non head changing machine that is the usual setting. If you have a head changer or use angle heads then you want it set as it is.
  8. #28
    Dec 2008
    New York
    8,389
    2243
    interesting, nice that it can be changed but i will leave the 4 cnc i use as is.
    the 3 horizontal cnc are set with more precautions to prevent crashes from inexperienced operators or just mistakes. the gantry cnc mill requires being extra careful. restarts require checking for G92 shift and seeing what G and M codes in effect. the horizontals are setup with (RESTART HERE) often in programs. saves a lot of scrap parts from happening
