Hello All,
I’ve got an issue with my G71 roughing program. I have scratched my head and looked and I just don’t see what the problem is? First run of this new program, everything is going just as it should until the very last roughing pass. It comes down the angle then swings the 4” radius then comes a cross the 1”dia. but instead of swinging the .38rad it plunged right into the shoulder. WTF? No I didn’t run it through the graph or out in dry land first.
I’ve attached some pictures of my drawing and the actual program and the end result. If someone could help me figure out what the deal is here I'd greatly appreciate it. At this point I’m going to go in and run the same program out in dry land and see if it does it again.
Other than that I got nothing. I hope you can see the drawing and pictures? The exact code is at the bottom.
Thank You….
Brent
N30(ROUGH OD)
G0G99G40G54X14.Z10.T0
T0303
M41
G97S150M4
G0X3.5Z.1M8
G50S700
G96S450
G71U.05R.05
G71P31Q32U.03W.003F.012
N31G1X1.4854Z.0000
G3X1.4950Z-.0063R.005
G1X1.2726Z-.4213
G2X1.0000Z-1.4566R4.
G1X1.0000Z-2.0100
G2X1.7600Z-2.3900R.38
G1X2.9400Z-2.3900
G1X3.0000Z-2.4200
G1X3.0000Z-3.3160
N32G1X3.5
M9
M1
Thank You….
Brent
N30(ROUGH OD)
T0303
M41
G97S150M4
G0X3.5Z.1M8
G50S700
G96S450
G71U.05R.05
N31G1X1.4854Z.0000
G1X1.2726Z-.4213
G1X1.0000Z-2.0100
G1X2.9400Z-2.3900
G1X3.0000Z-2.4200
G1X3.0000Z-3.3160
N32G1X3.5
M9
M1
