MICK 1958
Stainless
- Oct 1, 2008
- PITTSBURGH, PA.
I am in need of a cnc lathe and run across an Emcoturn 340, 1986 vintage with a Siemens 810 control, The owner said he never had it powered up and decided to sell it, I would agree to purchase if he could power it up and I could determine that it could be used.
I spent an entire day in his shop and he could not get it running, the little 7 inch screen illuminated, and read turret overload, his electrician says it keeps popping relays that are easily resettable in the rear of the machine.
I feel this is an omen to stay away from it, Am I being to hard on the machine? It seems to be the right size for my shop real estate constraints,
I am very open to another type machine, Some say to look for FANUC controls because of availability and price, what I have seen on here is that Siemens is pretty reliable ( read more dependable ) So that is why I am asking for advice on this potential purchase of my first cnc lathe.
I realize the machine is almost 25 years old, is this a good machine to learn on? or should I look for a newer version,?
I have looked at the HAAS TL1, seems over priced to me and with the "options" that I feel you MUST have (tailstock is an option?).....it seems like alot of money for a cnc/manual machine.
If I am going to spend 20,000+ dollars I think I should go full cnc, all advise will be taken with thanks. the Emco I spoke of at first is only 7,000 dollars which wont make me panic looking for work to feed it .
Thanx
Mick
Thanx
Mick
