Jims Machining
- Feb 15, 2015
Hello, I am having a few issues with my machine.
I went over to view it, seen it running parts, transported it over to my factory, fired it up and got the axis referenced no problem, I then did a little program to make sure it ran from a program I moved X Y Z in to the middle of each travel and powered down for the night. Came in the next morning and can no longer get it to run due to a "2200 Servo Stop Active"
This stops me from even doing the x,y,z ref on start up.
The hydraulic pump is no longer running unless I press the beaker in but with the servo stop active this also drops the head (z is now resting on wood on the table).
The only 2 errors I get are the servo stop active and unreferenced xyz.
First off does anyone know of the fix for maybe the cause for this problem off hand?
Checked so far:
All LED's on the main boards are solid green.
the only red LED I can find is on the Driver status section "PSE" is the lettering above it.
emergence stops have been checked.
Tried swapping phases over made no difference.
Checked the hydraulic and water pump for any faults or insulation problems this came back clean
In reality I need the service manual GEK - 25382
If anyone in the UK has one I can borrow for beer tokens I would been very thankful. Failing that there are some on ebay £150 ea inc postage
Any help is appreciated
James.
Checked so far:
James.
