Ox
- Aug 27, 2002
- Northwest Ohio
Fanuc 18T - prox 1997 vintage.
15 yrs ago (?) I had a ghost in this control. It would take the back end of this program and flop it over onto that program from random progs in the library. It was cornfusing, and a hassle, but it never did it to a program that was in use. Just an occasional prog in the library. So - no actual crashes.
Hardinge was clueless, but they referred back to Fanuc, and came back at me to dump all my prog's and reload.
So I did, and for 15 yrs it's been fine from that time on...
My library was not completely full at that time, but it was maybe 75% full?
The library has been completely full for some time now.
Now, I have since then had issues with an 18iT dooing the very same thing - if I let the library get too full. Dump it out and start fresh, and all is right with the world. This control has done this for many yrs, and will still doo this today if I fill the library up. But again - no worries as other than botched progs in the library, and possibly locking up the control, it has never caused an issue with a running program. It just makes a fella scratch his head when trying to set up the next job sometimes as you scroll through the prog - and it just doesn't make sence...
But recently - the original 18T (not i) that has NOT caused any grief in the last 15 yrs, has all of a sudden learned a new trick. It will sometimes decide not to bother running the toolchange (index turret) macro, yet thinks that it did, and continues on...
I am sure that it is NOT a mechanical issue as the turret is never mis-indexed. (not seated) and it is always at the exact same place in the prog and crashed exactly the same way. Now it may be a cpl hundred cycles between crashes, It may be several hundred. It may be less than 100, but the outcome is the same.
The CRT shows that the proper tool number is called up in the BRH corner of the CRT. Meaning that if T3 is s'posed to be up, the CRT reads T303 in the BRH corner, yet the turret is still in position 7 let's say... (It is not good)
I have put it in MDI and cycled an indexing prog with M99 to see if I could make it mess up between the two positions that it was missing the index on, but of course you can't make it doo it while you're watching...
It did it just now in a different place that the last cpl times on this same prog, but that appears to be b/c it did it during a Top Cut macro. But otherwise, it always does it at exactly the same place in any given program.
It seems to me to obviously be that the control is blowing through the macro that calls the tool change. Now - how that happens is way above my pay grade. But I am relatively sure that is what it is dooing.
This control has been "on" for most of it;'s life. Running most of it, but ON most all of the time. My mind was wondering on about what's the scoop, and I had a flashback to the computer "hairs" (?) or whatnot - that grow over time on circuit boards. Seems like they have addressed this to some degree over the years - maybe (Winders still crashes, so .....) but I think that I have ruled this out due to the NON-randomness of the issue. It doesn't doo it often, but when it does it - THIS is when it will doo it. Make sense?
I have completely dumped all progs and macro's. Left shut down overnight, over weekend, reloaded only the progs needed, and still there. I thought that it was gone at first - as it didn't miss-hit for a few days strait, but - it's back like a bad penny... (whatever that means)
Has anyone had any similar issues? And if so, what did you doo about it?
I have not been getting many hours on it lately as I don't bother to leave it run overnight - in hopes that shutting it down overnight will help it to be able to run through the day w/o crashing. ... having mixed results with that....
On the current job it likes to run the live cross drill that is in 4th position into the bar - thinking that it is a TNMG in pocket 3. I am down to my last collet nut for those holders, and it seems that my contact @ Gosiger must be MIA as I have not gotten any replies from my e-mails to her...
I have made a post-it note to CALL there tomorrow.
I have never dumped the params and such out.
That would prolly be next on my list to try.
However I might have to send it out to have the ladder dumped and reloaded. ???
Otherwise I will likely hafta git a new or at least used control for this.
I am Ox and I approve this h'yah post!
