good coolant for cnc mill?
Results 1 to 15 of 15
    Mar 2007
    warren, mi
    1,154
    116
    296
    Default good coolant for cnc mill?
    i'm looking for a good coolant for my cnc mill. the max pressure on the mill is about 300 psi and i would like something that is water soluable, doens't get nasty quickly and has good lubricity and cutting properties as most stuff i machine is harder metals like stainless, and titanium. my cnc lathes run straight oil, any reason i can't or shouldn't use that in the mill?
    Dec 2002
    Granville,NY,USA
    3,854
    255
    365
    There are quite a few opinions on this but Blaser and Hagstaffers (Sp) seem to be the front runners.
    I personally like the what I get from Blaser 2000 Universal MD. There might be a better product for your materials. A call to Blaser would answer that. That is what I did. I called them and talked about what I was machinining and they made a recommendation that worked well. I have only maintained my sumps since making the switch about 3 years ago.
    Nov 2007
    Alabama
    1,378
    125
    204
    There are probably 25-30 jobs shops in my area using Castrol 9930 or 9913.
    They all love it. Rather pricey but no worries.
    http://www.castrol.com/castrol/produ...tentId=6004223
    I have been through their metalworking fluids school but no I don't sell it.
    I wouldn't use straight oil.
    Dec 2008
    Canada
    64
    I have been using straight oils in VMCs machining stainless and various types of steel but not titanium. They say that the pulverized titanium chips are highly combustible (?) though I am yet to verify or bust the myth. Some water soluble coolants tend to get stinky and sludgy when unused for 2 days.
    Mar 2006
    Tennessee
    2,003
    249
    363
    I second the blazer 2000sw. Ive been trying differant coolants trying to find one that doesnt give me conjuntivitus and this is the only one that has worked so far.
    Oct 2008
    Iowa USA
    I'll 3rd on the Blaser. I've used 4000 strong though. Just watch your concentration. I've even had this stuff in the sump of an old #3 warner w/out it being cleaned out properly and it's held up. We run mostly 303 and 304 ss.
    Feb 2008
    154
    We switched to Master Chemical products a few months ago and now use Trim Microsol 585 (semi synthetic) in our Mori vmc and lathes. It was recommended to us specifically for its properties in cutting titanium. We've also gotten good results with 13-8PH stainless and case hardened steels.
    Prior to switching, we tried some synthetics with some major odor and minor rust problems.
    Feb 2007
    michigan
    60
    I am running True Blue synthetic. My machine uses too much oil and I am only a home shop. I don't have enough work to keep it busy so coolant can stand stagnet for a week or more at a time. It doesen't get stinky even after a year. No rust on cold rolled and tool life seems ok.
    Apr 2007
    Logan, UT
    96
    Quote Originally Posted by exkenna View Post
    why is that? Just out of curiosity. I have never been around a mill or lathe that has oil in it and always wondered why. Swiss machines seem to thrive with it. It never goes rancid, it has WAY better lubrication than most synthetics I have seen I just wonder why we don't put it in mills.
    Jun 2007
    SEATTLE
    331
    12
    I use Swiss Blaser 2000 and like it and they smell good at beginning
    I vote for Blaser 2000.
    I cut most aluminum
  11. #11
    Sep 2002
    gloucester ma
    1,614
    48
    947
    Default re
    2000cf for 5 years+ no problems, no rancidity, no replacement
  12. #12
    Jan 2008
    New Paris
    24
    Default Oil in Mills
    I run cutting oil in everything, swiss, hardinge bar machines and 2 haas vf mills. No problem with rust. On the mills I use what is called evaporative lubricant.Its a petrolium product clear and looks like straight water. It sure makes reamers cut right on and excellant finish compared to some water based I tried a couple of years ago. My 14 year old haas still looks almost new since no water based coolant has lifted paint or made thing a sticky mess. We mostly do small parts very little use with face mills, they leave a little mist or haze in the shop.
  13. #13
    Apr 2006
    Westside of America.
    3,288
    665
    875
    I'm a fan of Hangsterfers S500. Terrific lubrication, good sump life, and doesn't leave residue on anything. The worst I see is dark green dried up coolant that has turned back into concentrate. Just spray it down with more coolant and whatever it was on looks like new.
  14. #14
    Mar 2006
    Parowan,UT
    155
    Another vote for Hangsterfers S500. I use it on all materials. Plastics,Copper,Titanium, Inconel etc. Never had any problems.
  15. #15
    Aug 2002
    West Unity, Ohio
    22,690
    3152
    6149
    Default Bryco
    These guys are running lathes - but I would like to know what the old and new coolants are - as well as the materials being ran?
    artical here
    Just enough for the city.
    Ox
