ManualEd
Stainless
- Oct 13, 2014
- Kelowna, Canada
I have 50 slugs of 4.750" diameter x 4"long 4340HT that are turned into 50% chips.
The last time I ran them out of 4340 annealed a Sandvik CNMG433 4015 at 600sfm lasted about 30 parts/edge. At 30rc I imagine I'll be closer to 350sfm and half as many parts.
I'll have claw jaws holding on to 18mm of stock, so I should be able to push it at .150"DOC, .014"/rev ish.
I'm a big fan of the Walter WPPxxS grades with an RP5 chipbreaker in the manual lathe. Nice low cutting pressure required compared to other inserts with a flat edge.
I lean towards process reliability rather than having to swap inserts every 10 minutes.
Anything magical grade out there that will last at 800sfm?
Thanks a lot!
Thanks a lot!
