ncimike3
- Mar 30, 2012
- Paramount, California USA
I have a Mori ZL-25 twin turret lathe with fanul 11TT control. I'm trying to get up and running parts from a bar with a new collet chuck and bar puller. The collet clamps and unclamps just fine when manually using the foot switch. Also the collet opens and closes when using the key switch which switches between od clamping or ID clamping. But in MDI or in Memory (Auto) mode the program will hold until I use the foot switch. Once the foot switch unclamps (or clamps depending on what the block calls for) the program will then continue to run. The program runs from "cycle start" just fine with the exception that the chuck never opens up when called out. Of course I start the cycle start with the chuck closed. I thought maybe there was a parameter setting that disabled the M10 or M11 commands. I looked through the parameter list and found no such parameter. Any ideas? Thanks for any help.
Mike
Mike
