pdexter1210
- Oct 21, 2014
We picked up a nice (albeit stuck at the time) Haas 310 rotary table and have got it cleaned up and in good working condition again. We have a job that we're looking to use it on, but need a chuck attached to it, as it only has the face plate at the moment. I have a new 12in Bison 3 jaw that I would like to attach and have been looking at options for setting it up. At this point, I'm considering getting a 12 inch cast iron blank back plate, machining it to fit the chuck and bolting it to the chuck, then using a piece of bar stock and mounting the the Bison chuck in the manual lathe using the bar stock in order to machine a shoulder on the back surface of the back plate to a slight interference fit into the face plate on the rotary.
Not looking to reinvent the wheel if there is a better way, so thought I would ask how others would do it? I've priced the chuck setup from Haas, so I'll pass on that. Other ideas?
