haas door interlock parameter?
Results 1 to 5 of 5
    Sep 2006
    IN
    Default haas door interlock parameter?
    I have just started a new job in a small shop with 3 haas mills. I have been accustomed to turning off the door lock override with the past hass's I've experienced in with setting 51. Now, two of these three, (the older ones, 2002, 2004) allow me to set setting 51 to allow door open functionality. But the newer one, it doesn't work on that one. As I remember, the haas tech asked me if I wanted this option turned on or not when he installed the machine. IT IS NOT SETTING 51!! tHERE IS A PRELIMINARY PARAMETER! I wonder what it is! Does anyone know what parameter this is, or maybe I need to call haas.
    Jan 2007
    FL
    587
    9
    On the SL20 lathe I ran, I always just left a magnet on the little magnet interlock at the top of the door to override it. That way I could use the auger with the door open, and I didn't have to bother going into the settings every time I powered it up.
    Mar 2007
    Aylesbury, U.K.
    232
    11
    Does your boss know you are overriding the safety interlock?
    Whether he knows about it or not you are putting his a** on the line by doing this. When the accident happens your lawyers will take him to the cleaners and Health and Safety agencies will be down on him like a ton of bricks.
    I wonder if Haas does not allow this any more because of litigation concerns.
    It is a SAFETY interlock.
    Regards,
    Mike.
    Nov 2006
    A little NW of Mt. Rainy-er in Washington State
    200
    Well, should I tell him, guys? First you change the PARAMETER in 51 (or is it in 57?) then everytime you start up the machine you go to SETTING and enable "door hold override".
    Apr 2018
    New Jersey
    Default Finally a real fix.
    Quote Originally Posted by purplechip View Post
    Ok so this only works for machines that have setting 51. First you need to turn off parameter lock in setting 7. Make sure to press the E-stop before the next step. Go to parameter. Under parameter common 57:31 it should say “door stop spindle”. You want to change that to 0 (zero). Now you can change setting 51 to on, and you should be good to go. Hope this helps everyone, took me a long time to figure this out. Enjoy.
