breed6903
- Mar 18, 2013
- Peoria, IL
Looking for some help with the HAAS IPS programming system. I am trying to do a tool path off of a dxf file with a irregular shape. The irregular shape is on the inside of a rectangular part.
I can select the geometry lines perfectly then next step is pocket or contour. When contour is selected it askes for entry point but wont allow me to jog the entry point to the inside of the hole or pocket. It thinks the cutter should be on the other side of the line.
Anyone else run into this?
please respond to below email
[email protected]
[email protected]
