H_Vordos
- Jan 14, 2005
- Onalaska WA.
Hello folks!
I'd like to begin by saying that I am not CNC literate. I retired from the trade, having worked as a machinist/toolmaker, but on manual machines exclusively. It is safe to say I am a CNC moron.
Fast forward to a few years ago, when I acquired a used Haas TM-1 (basic tool room mill), which has no tool changer.
From the outset, the machine, when started, would occasionally give an alarm message in regards to the Y axis, but simply retrying the Powerup/resart button seemed to cure the problem. That is, until yesterday. The machine now shows the same error message, as well as a similar message for the Z axis. In addition, when the machine is trying to find zero, both the saddle and table run the wrong direction. Both run at a much reduced speed in this condition.
I live in fear that the problem is with the electronics of the machine, but wanted to see if anyone, here, might have something useful to suggest. Living on social security, hiring a tech isn't in the cards, although that may be the only solution.
Any help I might receive would be appreciated.
Incidentally, the machine has relatively low hours, and has sat, unused, for long stretches, often a year or more. What little use it has seen with me is in machining small aluminum components, including some engraving.
Harold
Harold
