Hey guys, I hope someone here can help me with some Parameters Settings
To get to this screen you will need to change the Rotary Switch on the upper left of the master board to 4, then turn on the control while pressing the shift key. You should get the following screen.
Now you will press the Function Parmeter button then the soft key parameter button. This should take you to the parameter menu screen.
Thanks in advance.
Thanks in advance.
