So over the past week my 20015 haas vf2ss has started to develop some taper locking issues. Essentially a moderately loud thunk (non metallic - making me believe its taper lock and not drawbar related) upon tool release. It hasnt gotten to the point of a failed tool change but i fear it will get there eventually. A little info - Its cat40 (i dont even think they offer a vf2 with any other size) and it only happens with ONE tool. Its a harvey 3/16 downcut endmill designed for plastics. Im roughing in plastic with a high speed toolpath that runs for about 25min. The same tool runs for about 2 min later in the program and does NOT have any problems with tool release during that time.
I have tried every holder i can fit that tool into hoping it was just a bad holder. All my holders are maritool, ordered from maritool. So they are quality. That did not change a thing. So i decided to check taper engagement and i am well within 80% engagement. I keep my spindle and tool tapers very clean and never leave a tool in the spindle over night or weekends. I have tried the "grease the top inch of the tool holder and pullstud" and that changed that nothing. The spindle casting never gets even remotely warm to the touch so the tool holder shrinking in doesnt seem to be the case. We purchased this machine with 14000 hours on it about 3 months ago and it went through a whole inspection by haas techs. The spindle taper, along with everything else, was deemed well within factory specs. The drawbar pull force was right around the 1700lb mark. I spoke with a haas service tech and he had less input than my google searches, i did however find out that this year of vf2ss does not use a precharge on the drawbar during a tool change so that has been ruled out as well.
The only things that i can think that are causing this would be the fact that its a downcut endmill causing all the cutting force to go towards the spindle instead of away from it. Or the fact that my shop is based in az and the past week was the first week of consecutive 100+ degree days. My shop is swamp cooled and never gets above 80 degrees inside. I do make sure to leave a light film of oil on anything i dont want rusting every evening even though it does not seem to get humid at all in the shop.
If anyone has any insight on what could be causing it or any advice on things to try it would be greatly appreciated. I was less than impressed with the service tech i talked to, and would really rather not have him try and diagnose this. Let alone even touch my machine.
