implmex
- Jun 23, 2002
- Vancouver BC Canada
Hi All:
I just got a set of form cutters from AB Tools for milling a conical Oring seat in 316 SS on a production job.
I couldn't be happier with what they made for us!!!
Normally I grind or wire cut all our own formtools, but since this is a moderate volume production job and we needed really tight consistency from cutter to cutter, we decided to go with an outside vendor.
Alfred and his guys did a brilliant job on these.
I gave them the material spec, and the profile geometry and asked them to use their own judgement on what to make for us: we got back a 3 flute cutter, uncoated with about 5 degrees of positive rake.
These things cut slicker than snot and leave a beautiful finish; better than I was able to achieve with the form cutter I ground to do the process planning and prototyping, and I took a fair bit of care making that first cutter because of the tight finish requirement.
So all of you that need form cutters...go to Alfred at AB Tools!
Cheers
Marcus
www,vancouverwireedm.com
Cheers
Marcus
