Hard milling
Results 1 to 5 of 5
Thread: Hard milling
    Nov 2013
    georgia usa
    Default Hard milling
    I am new to the forum so i wanted to start with a question i would typicly google. I have a customer that is having issues milling hardend cam's. I don't want to spend to much time on trial an error so what is recomended for this type of application? High torque spindle, high speed low feed carbide cutting, etc. I have done this in the past but not as a continues process. Any advise will be helpfull.
    Bt 30 tool holders
    Mar 2013
    New York
    3,741
    2705
    2376
    Hsmadvisor.com use the free 30day trial. Youll be hooked
  3. Likes Hertz liked this post
    Jun 2011
    Pittsburgh, PA
    5
    Depends on how hard the material is but I've had a lot of luck with high feed cutters taking light passes
    Oct 2012
    Canton, OH
    195
    24
    26
    If you can side mill with a cabide end mill the new HSM techniques make this a snap.
    plus one on Hsmadvisor.com
    Apr 2008
    london or espania
    92
    43
    done loads of this whilst toolmaking
    typically:
    use ball nose and tip rad cutters
    coated micrograin carbide
    air blast not fluid coolant
    light cuts
    eg:
    6mm (1/4) ballnose, up to 55 rc, should be doing 10500 rpm at 650mm/min feed (25 inch/min)
    depth of cut approx .25mm (10 thou)
    stepover 0.25mm (10 thou)
    i have done plus 55 rc, but it is hard work, better off grinding then.
