Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By mackie29
Thread: Heidenhain control
    mackie29 is offline Plastic
    Apr 2010
    canada
    39
    Default Heidenhain control
    Hello we have an Heidenhain 530i. No one here has ever run it before is there away to see how much you are offsetting down with the handwheel can get it to offset just don't know how much it has gone down.
    Boris is offline Titanium
    Oct 2005
    England
    2,875
    Asssuming it has the 410 handwheel unit (or something similar) attatched to it
    The handwheel has a fast, medium and slow speed option on it, but theres no set value for distance moved vs how far you turned the wheel , but saying that, the handwheels have quite a fine pulse generator in them,
    unlike the rather coarse fanuc ones, so that if you put the hand wheel in slow speed, and rotate the hand wheel slowly, the selected axis will move very slowly.. fine enough for me to use a electric edge finder and be able to set the machine within 0.0002"
    Alternatively, you can put the machine in manual jog mode, set the distance to be moved to say 0.01mm , then for each press of the axis jog button, the axis machine will move 0.01mm (I do not like this mode and hardly ever use it)
    If you need a manual for the control, just search the HighAndPain website under 'documentation' and you'll be able to d/l a 600 page PDF file containing all you need to know, and lots more you did'nt
    Boris
    PS heres a couple of spare commas to use ,,
    swarf_rat is offline Stainless
    Feb 2004
    Napa, CA
    1,757
    To add to what Boris said, there are three parameters that set how fast the slow-medium-fast speeds are (usually MP7670.0-2 but I haven't checked a 530 control). If the slow is set really slow, there is no problem positioning to 0.001 mm (0.00004") if your machine is capable.
    Apr 2010
    canada
    39
    Thanks the handwheel is an Hr520 with the digital display. the problem is seeing how much we have offset with the handwheel.On the other controls we have it shows how much you have offset can the Hiedy do this. Also does the offset stay active say like on an Fida controllar.
    Thanks again Mike
    bryan_machine is offline Titanium
    Jun 2006
    Near Seattle
    2,439
    Are you talking about the feature where you say you want to offset a running program? I've never used that.
    For normal uses, the position displays will move with the tool and the handwheel, and will show you position relative to the current working coordinate system - of which you can have an arbitrary number (as many as will fit on the hard disk basically.)
    Apr 2010
    canada
    39
    Yes while running an program I should of put that in there to0
    Wlybaddad likes this.
    Feb 2012
    Michigan U.S.A.
    11
    Try M118 That should allow you to do what you want.
    jerryzak's Avatar
    jerryzak is offline Aluminum
    Dec 2007
    Kingston, Ontario, Canada
    111
    I'll take HH over any other system I used (never used FIDIA) any day.
    Jerry
    Hansdie's Avatar
    Hansdie is offline Hot Rolled
    Jul 2005
    San Francisco, CA
    651
    Quote Originally Posted by mackie29 View Post
    Mod key then set your position display to M118
