First let me re introduce myself Ive been on the forum since 2003, I cant remember the last time I posted. I have a new position as a Machinist/Instructor in a college with old equipment.
The problem is the; trying to run any program I get LIMIT SWITCH Z+ error, I have tested the switches all are working & restarted the machine several times.
Any Ideas?
Check the parameters, the Z+ is probably set wrong.
my R2C3 is set as follows:
MP 44 : +457,327
MP 45 : -1,270
MP 46 : +304,928
MP 47 : +0,000
MP 48 : +2,000
MP 49 : -127,127
44,45 are x
46,47, are y
48,49 are z
in mm, allowable travel from the zero encoder pulse.
If it is an Interact, the y will be different. it homes in the opposite direction
the numbers are to give you an idea of the appropriate range, all the machines have their own numbers
the heidenhain does not limit switches per se, it has a Z+ trip dog, which if it is electrically stuck, will cause the z to move down during homing, then the first encoder marker pulse it sees is zero. The trip dog is very close to Z+Max, so if this switch is sticking it will have little to no movement in the up direction, and will eventually hit the actual Z- limit switch. Hitting any of the actual limit switches will result in an EMO and you will have to move it off manually
The other thing that could be happening is that you have your Z set incorrectly. If you have Z zero set as the very top of the travel, you will have travel available only by programming -Z numbers, as you can see, my machine will give that error if you program any positive Z number larger than 2 mm, if it was zeroed at the topof travel
