Wow....
Some WOW! and some not-so-wow.
Here's my short? version response....
I've heard of people dissatisfied with integrators (vendors) and I know one guy that tossed a "CNC services" (Centroids approved vendors-retrofitters) guy out of his shop. Nothing new with retrofitter types really. Not good either. If the guy dosen't know the machine uses resolvers......that's just dumb and a BAD sign.
I've NEVER done a Centroid Ajax retro.
Yet.....
I have done several Fagor lathe and Mill retrofits.
They (and I suspect -most- controls) have some similar issues as you describe.
Read: You are NOT alone here, these are the part of the initiation process of learning how to retrofit a machine tool. Knowing the difference between an encoder, resolver, and a pot, -already- puts you in the Junior-advanced catagory!
I have some real crappy hour and WEEK wasting war stories of my own...that I'll spare us all from right now....well almost....
Spindle motors 101.
Welcome to the club.
20 hours?..ha!
That's 40 less than it took me to learn on my first one. See below.
DC motors are WAY better for spindles (without a gear box) than AC VFD's.
Hey, BETA was supposed to be WAY better than VHS too remember!??
Lucky for me, before I replaced a spdl motor on my small 5C spindle CNC lathe, I did one on a Bridgeport for a "paying project". Customer specified 2HP VFD for 2HP motor. I bought a 3HP
VFD. Real eye opener.
Words like "mush" and "rubber band putty" come to mind in describing the non-existent torque below 500-800 rpm.
Then it was my fault when they couldn't drill 3/4" holes in steel w/o a pilot hole (not in back gear, 200RPM). haha.
So, when the 8HP DC spdl drive on my lathe popped, I did some research on torque curves, threw the notes away, and installed a 15HP AC motor & 15HP VFD. And it -still- doesn't seem to have -as much-
torque as the DC below 500 RPM.
The 5HP VFD for the 16C CHNC just makes me chuckle. WAY way under powered. That HB headstock, bed & collet size should handle the torque from a 20HP VFD -NO- problem.
Then it wouldn't thread. Because (after 4 days of head-scratching) the VFD was SO noisy, the cnc couldn't see the spdl encoder marker pulse.
Days & dollars$ later, with reactors & supressors & chokes installed, she threads just so fine!
But that's another war story....
But I digress......
Seems like any +/- 10VDC analog (or is it 0-10V?) spdl drive should work withthe Cent control.
PLC changes for extra charge sounds like nickle/dime padding to build profit into services
that should be included. Another bad sign of apparent not-so-good integrator.
Shame.
G33 VARIABLE lead?
Interesting.....
Never heard of it.
Have to check the Fagor & see if it allows Var. lead on the G33.
Not suprized Cent steered clear of it.
Probably not much call for it for what it would take to write the G code.....and DEBUG it.
$2000 Price typo.....
What can I say?
Things (like the AC servo drives) they were "selling" appear and disappear on their web site all the time...
Centroid being distant with your direct inquiry:
Probably acting "in the best interest" of their "approved vendor".......??????
A good impression for you? NO!
Smart on their part?...nope.
Patameter mismatch:
Unfortunate, but goes with the retrofit territory.
Don't bet on or believe any parameter until you check them .....2 or 3 times.
A bitch when it's supposed to be "bolt on", but the vendor (a sharp one) normally would deal with it -fairly- easily....having "been there done that".
But now YOU know so much more about retrofits!
Fagor dosen't "govern" the spindle speed either.
Don't think many (OK a $20K FANUC might) controls do. Don't really need it. In G33, if the spdl slows down, the z axis feed slows proportionally.
In G1/IPR feed, same thing.
Same with programmed vs actual speed.
Usually have to play with min/max speed parameter settings and "fake out" the control to get the programmed speed to sorta match the actual RPM.
LOTS more hunting and less accurate with a VFD than a DC drive! I've had DC spindles hold within 1 rpm over the 25-4000 range. DC drives are just plain tighter.
CSS on tool change:
Fagor does that too. Big deal.
Switch back to RPM before the T/C in the program, then CSS after T/C. I usually rapid close to the part -then- go into CSS, then start feeding.
Sometimes I don't. And the spdl motor is ramping up/down alot. So what?
Braking resistors:
You can sometimes save big bux by going to Home Despot and buying a $8 electric stove element (or 2) instead. The ohms are usually close enough to work. Haas is so cheap THEY use them on their
machines.
This is getting sorta depressing......
Anyway.....
Program crashing with M codes or door opening.
Let me guess.....there's some sort of switch on the door??
It "sounds" like some relay or solonoid coils are spiking the PC. You might need some Arc-killers or suppressors or diodes across those coils....??
Pendant:
I really WANNA believe you can change some parameter to swap those X keys.
Please BUG them till you solve that (saftey) issue.
Hint: Can't hurt to mention it's a SAFTEY issue with their hardware!
.......and call 2 dozen times on the problem in 3 days if you must.
(Before you or an operator gets injured).
Turret encoder:
The potted one?
What a rube goldburg pile of crap.
Maybe the encoder itself is faulty, magnet weak,
mis adjusted???
Wish it was a "real" encoder or prox switch.
Linux:
Agreed, what for?
DOS works fine.
Have you calculated the resolution of the system?
Is it .0002 or .0001 with 2000 line encoders?
PLC Direct sells Koyo encoders for around $75 that I think go up to 2500 line, maybe higher. They are very relaible.
Getting a written quote with itemized list of whats included helps elminate the "didn't see it" excuse from vendors.
I hope the issues can and WILL be resolved on your machine. It's all up to you to make "squeaky wheel" noises....LOUD if need be.
How far are you from Howard,PA?
I'd arrive on their door step some day and camp out
till I got results.
>Dan, we've never met so I assume you're not really >accusing me of giving misinformation so I can >clear out junk.
Ok, but I've exposed a potential opportunity
for you to cash in and get rich with an inflated
pricing scheme.
..........JUST KIDDING........
dan k
