I'm curious about this. I have 5 tools that always stay in the magazine and are used on almost every part and program I run. The only time I change the length offset or radius comp values are when I replace the tool. What is going on that you need to change those values for each different program?
T03 is a .125 Harvey Tool 300deg undercut ball deburring tool. We're using this to deburr the top and bottom of the holes drilled in the part on a radial surface. I had to make different WC offsets for the top/bottom, so it can be adjusted easily, especially the Z. When we change over from part to part, the hole dia changes as well, along with the chamfer size.
When I wrote the program in MasterCam, I used a simple X0. Y0. WC for the toolpath, which gives me the basics.
Out at the machine, I still need to tweak it it a bit. This option does that.
I know if MasterCam was fully setup for our 5axis Nikken, this would go number for number.
MasterCam gives an option for tool comp (Tip or Center). I need something in between.
Imagine the first option for cutting contact was at 3o'clock. The second option was at 6o'clock. I need option three at 4:30.
I'm just learning how to do all this, so over time, things may change, but for now...it works.
Hope that clears up the confusion.
