Hey Everyone,
I could use some help with getting my tool change subroutine to work on my 8025M router. The tool changer is a Non-Random 6 tool changer (basically just X/Y tool positions {ISO30 tool clips} mounted along the long side of a 4'x8' table). Here is a rough diagram:
....._T1_T2_T3_T4_T5_T6_
__/____________________\__
|......................................| Y=4'
|o_______________________| v
<----------- X=8' --------->
After a machine reference (Home):
The absolute coordinates of the table origin are at (X6.365,Y0.135,Z-5.75).
The absolute coordinates of T1 are @ (X39.643,Y59.990,Z-4.702).
The TC subr references the position of T2-T6 to the positon of T1.
The table soft limits (absolute referenced from machine ref zero) are:
XPos=111.0, XNeg= -1.0
YPos=61.5, YNeg=-0.5
ZPos=1.0, ZNeg=-5.75
There are two programs that I am trying to use (attached at the bottom of this post). The first program (%43210) is a short program that simply calls for a tool change. The second is the tool change subroutine (%99998). The TC subr has a lot of comments included here, but I have stripped them out on the version that I have loaded on the machine.
PROBLEM
When I try to just run the %99998 in single block mode, I get the following:
Error 016 : N _ _ Doesn't Exist
N0310 G26N3000.3030
The Error Code Book says: Error 016 - The called subroutine or block does not exist or the block searched by means of a special function F17 does not exist.
As I scroll thru the lines of code on the machine, the blocks N3000 thru N3030 are definitely in there, but?!?!?!
Any help or insight would be greatly appreciated.
R/Todd
Here are the two programs:
%43210
%43210
N0040 G90
N0050 G70 (Inch)
N0060 G59 X0 Y0 Z0
N0140 M05
N0200 T6.6
N0220 M6
N0280 G0 X0.0 Y0.0 Z0.0
N0290 M05
N0540 M30
%99998
%99998
N0010 (TOOL CHANGE PROGRAM WITH NEW X&Y AXES)
N0020 ()
N0030 G22N99 (DEFINES THIS AS A STANDARD SUBROUTINE NUMBER 99)
N0040 G90 (SET ALL MOVES TO ABSOLUTE PROGRAMMING)
N0050 G53 (ZERO ALL OFFSETS)
N0060 M5 (TURN SPINDLE OFF)
N0070 P40=K39.643 (X BASE POS - X POS OF TOOL #1)
N0080 P41=K59.990 (Y BASE POS - Y POS OF TOOL #1)
N0090 P42=K-4.702 (Z BASE POS - Z POS OF TOOL #1)
N0100 ()
N0110 (P45=LAST OR OLD TOOL NUMBER)
N0120 (P49=SELECTED OR NEW TOOL NUMBER)
N0130 (P50=CALC X POS FOR OLD OR NEW TOOL)
N0140 (P51=CALC Y POS FOR OLD OR NEW TOOL)
N0150 (P52=CALC Z POS FOR OLD OR NEW TOOL)
N0160 P53=K57.000 (SET P53 TO A TEMP Y POSITION 1)
N0170 P54=K50.000 (SET P54 TO A TEMP Y POSITION 2)
N0180 ()
N0190 (-------------------------------------------------------------)
N0200 (DETERMINE THE OLD TOOL NUMBER FOR X,Y&Z CALCS)
N0210 ()
N0220 P23=P45 (SETS PARAMETER P23 = LAST/OLD TOOL NUMBER)
N0230 (IS THIS OLD TOOL #1 ?)
N0240 P49=P23F2K1 (IF O.T.#1-1=0, THEN DO NEXT LINE, ELSE SKIP)
N0250 G26N1000.1030 (IF O.T. WAS #1 THEN GOTO LINES 1000 TO 1030)
N0260 (IS THIS OLD TOOL #2 ?)
N0270 P49=P23F2K2 (IF O.T.#2-2=0, THEN DO NEXT LINE, ELSE SKIP)
N0280 G26N2000.2030 (IF O.T. WAS #2 THEN GOTO LINES 2000 TO 2030)
N0290 (IS THIS OLD TOOL #3 ?)
N0300 P49=P23F2K3 (IF O.T.#3-3=0, THEN DO NEXT LINE, ELSE SKIP)
N0310 G26N3000.3030 (IF O.T. WAS #3 THEN GOTO LINES 3000 TO 3030)
N0320 (IS THIS OLD TOOL #4 ?)
N0330 P49=P23F2K4 (IF O.T.#4-4=0, THEN DO NEXT LINE, ELSE SKIP)
N0340 G26N4000.4030 (IF O.T. WAS #4 THEN GOTO LINES 4000 TO 4030)
N0350 (IS THIS OLD TOOL #5 ?)
N0360 P49=P23F2K5 (IF O.T.#5-5=0, THEN DO NEXT LINE, ELSE SKIP)
N0370 G26N5000.5030 (IF O.T. WAS #5 THEN GOTO LINES 5000 TO 5030)
N0380 (IS THIS OLD TOOL #6 ?)
N0390 P49=P23F2K6 (IF O.T.#6-6=0, THEN DO NEXT LINE, ELSE SKIP)
N0400 G26N6000.6030 (IF O.T. WAS #6 THEN GOTO LINES 6000 TO 6030)
N0410 ()
N0420 (------------------------------------------------------------------)
N0430 ( REMOVE THE OLD TOOL FROM SPINDLE )
N0440 ()
N0450 G0YP54 (MOVE Y TO TEMP Y POSTION Y2)
N0460 XP50 (MOVE X TO CALC X POS FOR IN/OUT OF CUR TOOL)
N0470 YP53 (MOVE Y TO TEMP Y POSITION Y1)
N0480 ZP52 (MOVE Z TO CALC Z POS FOR IN/OUT OF CUR TOOL)
N0490 M89 (DECODED M FUNCT FOR TSDEVICE RELEASE)
N0500 G1G7YP51F200 (MOVE RACK TO SPINDLE IN SQUARE MOTION)
N0510 (G7 = Y MOVE MUST BE DONE BEFORE Z1 MOVE)
N0520 M91 (DECODED M FUNCTION FOR RELEASE DRAWBAR)
N0530 G4K1 (DWELL FOR 1 SEC)
N0540 Z1 (MOVE Z TO ABSOLUTE Z=1.0 - APPROX 5.5" UP)
N0550 G0YP54 (RAPID Y TO TEMP Y POSITION 2)
N0560 ()
N0570 (---------------------------------------------------------------)
N0580 (DETERMINE NEW TOOL AND CALC NEW POSITIONS)
N0590 ()
N0600 P29=F29 (SET PARAM P29=VALUE OF NEW TOOL#)
N0610 (FOR NEW TOOL = 1)
N0620 P49=P29F2K1 (IF N.T.#1-1=0, THEN DO NEXT LINE, ELSE SKIP)
N0630 G26N1000.1030 (IF N.T. IS #1 THEN GOTO LINES 1000 TO 1030)
N0640 (FOR NEW TOOL = 2)
N0650 P49=P29F2K2 (IF N.T.#2-2=0, THEN DO NEXT LINE, ELSE SKIP)
N0660 G26N2000.2030 (IF N.T. IS #2 THEN GOTO LINES 2000 TO 2030)
N0670 (FOR NEW TOOL = 3)
N0680 P49=P29F2K3 (IF N.T.#3-3=0, THEN DO NEXT LINE, ELSE SKIP)
N0690 G26N3000.3030 (IF N.T. IS #3 THEN GOTO LINES 3000 TO 3030)
N0700 (FOR NEW TOOL = 4)
N0710 P49=P29F2K4 (IF N.T.#4-4=0, THEN DO NEXT LINE, ELSE SKIP)
N0720 G26N4000.4030 (IF N.T. IS #4 THEN GOTO LINES 4000 TO 4030)
N0730 (FOR NEW TOOL = 5)
N0740 P49=P29F2K5 (IF N.T.#5-5=0, THEN DO NEXT LINE, ELSE SKIP)
N0750 G26N5000.5030 (IF N.T. IS #5 THEN GOTO LINES 5000 TO 5030)
N0760 (FOR NEW TOOL = 6)
N0770 P49=P29F2K6 (IF N.T.#6-6=0, THEN DO NEXT LINE, ELSE SKIP)
N0780 G26N6000.6030 (IF N.T. IS #6 THEN GOTO LINES 6000 TO 6030)
N0790 ()
N0800 (-------------------------------------------------------------)
N0810 (NEW TOOL INTO SPINDLE)
N0820 ()
N0830 XP50 (MOVE X TO CALC X POSITION)
N0840 YP51 (MOVE Y TO CALC Y POSITION)
N0850 G1ZP52 (LINEAR MOVE Z TO CALC Z POSITION FROM Z1.0)
N0860 M92 (DECODED M FUNCTION FOR DRAW BAR HOLD)
N0870 G4K1 (DWELL FOR 1 SEC)
N0880 G0YP53 (RAPID Y TO TEMP Y POSITION 1 - TOOL OUT OF HOLDER)
N0890 Z1 (MOVE Z BACK UP TO ABS Z=1.0)
N0900 YP54 (MOVE Y TO TEMP Y POSITION 2)
N0910 M90 (DECODED M FUNTION FOR TSDEVICE HOLD)
N0920 P45=F29 (SET P45 = NEW TOOL# DETERMINED ABOVE SECT)
N0930 G24 (END OF SUBROUTINE)
N0940 ()
N0950 (------------------------------------------------------------)
N0960 ()
N1000 P50=P40 (CALC X FOR TOOL #1 = X BASE POS VALUE)
N1010 P51=P41 (CALC Y FOR TOOL #1 = Y BASE POS VALUE)
N1020 P52=P42 (CALC Z FOR TOOL #1 = Z BASE POS VALUE)
N1030 ()
N1040 ()
N2000 P50=P40F1K6.004 (CALC X FOR T#2 = X BASE + T2 X OFFSET)
N2010 P51=P41F1K-0.042 (CALC Y FOR T#2 = Y BASE VALUE)
N2020 P52=P42F1K0.044 (CALC Z FOR T#2 = Z BASE + T2 Z OFFSET)
N2030 ()
N2040 ()
N3000 P50=P40F1K12.020 (CALC X FOR T#3 = X BASE + T3 X OFFSET)
N3010 P51=P41F1K-0.137 (CALC Y FOR T#3 = Y BASE)
N3020 P52=P42F1K0.105 (CALC Z FOR T#3 = Z BASE + T3 Z OFFSET)
N3030 ()
N3040 ()
N4000 P50=P40F1K18.005 (CALC X FOR T#4 = X BASE + T4 X OFFSET)
N4010 P51=P41F1K-0.077 (CALC Y FOR T#4 = Y BASE)
N4020 P52=P42F1K0.142 (CALC Z FOR T#4 = Z BASE + T4 Z OFFSET)
N4030 ()
N4040 ()
N5000 P50=P40F1K24.051 (CALC X FOR T#5 = X BASE + T5 X OFFSET)
N5010 P51=P41F1K-0.150 (CALC Y FOR T#5 = Y BASE)
N5020 P52=P42F1K0.209 (CALC Z FOR T#5 = Z BASE + T5 Z OFFSET)
N5030 ()
N5040 ()
N6000 P50=P40F1K30.0 (CALC X FOR T#6 = X BASE + T6 X OFFSET)
N6010 P51=P41F1K-0.188 (CALC Y FOR T#6 = Y BASE)
N6020 P52=P42K0.57 (CALC Z FOR T#6 = Z BASE + T6 Z OFFSET)
N6030 ()
N6040 ()
PROBLEM
N0310 G26N3000.3030
R/Todd
%43210
%43210
N0040 G90
N0050 G70 (Inch)
N0060 G59 X0 Y0 Z0
N0140 M05
N0200 T6.6
N0220 M6
N0290 M05
N0540 M30
%99998
%99998
N0020 ()
N0100 ()
N0180 ()
N0210 ()
N0410 ()
N0440 ()
N0560 ()
N0590 ()
N0790 ()
N0820 ()
N0940 ()
N0960 ()
N1030 ()
N1040 ()
N2030 ()
N2040 ()
N3030 ()
N3040 ()
N4030 ()
N4040 ()
N5030 ()
N5040 ()
N6030 ()
N6040 ()
