hello,
We have an old makino fnc60 vmc with fanuc0m control, the ATC is not working , so we manually change tools, recently we started facing problem as described below
we are in the miiddle of a program , change tool manually and press cycle start when the Z axis is in motion first rather than the x and y which should bring the part to position, this happens intermittently say once in a day .
any suiggestions on the cause of this problem
thanks
rags
thanks
rags
