kazlx
Hot Rolled
- Nov 22, 2010
- Tustin, CA
I have a pretty old ('89) drill/tap machine that doesn't have any way to drip feed code. The control is a Fanuc OM-Mate I'm trying to figure out if I can sort of get around this by programming one/two parts and then using that as a subroutine inserted into a short master program telling the machine to go to different work offsets and repeat at different vises/locations. This way I can use my two vises to run duplicate parts and maximize spindle time. Does anyone have a sample of this that would help? I'm currently using Fusion 360. Posts run fine and machine runs good parts, I'm just not sure how the logic/programming should go to achieve this.
I found that it looks like you call a subroutine for a program by using P instead of O with the appropriate program number.
Disclaimer: I'm not super savvy with manual code entry, but trying to learn.
