Help with Matsuura errors
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Dec 2006
    Utah
    79
    Default Help with Matsuura errors
    A little background, I have a 30hp American Rotary phase converter powering my MC-760V (MX-1 controller). I watched the machine run before I had the rigging company move it to my shop. I have it all wired, when I try to start it only the fans come on, the hydraulics do not come on.
    The errors I am getting are, in order:
    330: Emergency stop
    310: Servo off
    I know about hitting the green start button to turn on the servos. But nothing happens. Holding the reset and start button does nothing too. Both e-stops are released.
    The machine has air, all fluids are full. I have researched and found a few threads about the error but no one updates the threads to say what their errors were caused by.
    Any help would be appreciated, thanks.
    Jun 2004
    Melbourne Australia
    5,148
    Since you have just installed it, first thing I’d do is check for phase rotation. I’d assume that’s a 3 phase 200V machine?
    I normally find the cheapest 3 phase motor on the machine, coolant pump, swarf conveyor etc, that has a direction arrow on it. Then find the motor contactor for it and give it a manual jab. You need some one watching the motor. You could even use the hydraulic motor as a last resort, but just for a short time.
    Phil.
    Dec 2006
    Utah
    79
    Quote Originally Posted by machtool View Post
    Phil.
    Yes it is 3 phase but it is 240V. I will try that thanks!
    May 2005
    Vancouver, WA
    465
    18
    Is the chiller connected and turned on? Typically, the chiller, coolant pump overload, and hydraulic pump overload are wired to the e-stop loop. Did you get the wiring diagrams for your machine?
    Dec 2006
    Utah
    79
    Just pushed the coolant contact, rotating correctly. I was able to go to the controller, clear the alarms, move the table/spindle, then it errors out again (same two as before) within a minute.
    Dec 2006
    Utah
    79
    Quote Originally Posted by CPT Crunch View Post
    No I did not get the wiring diagram for the machine. But the wiring diagram for the cooler was on the lid of the cooler. Plus all of the wires were numbered as were the termanals.\
    Any other ideas?
    Mar 2005
    Hermosa Beach California
    3,676
    25
    68
    Damn im sorry you're having that problem.
    That Error you're getting is a very standard (common) error.
    Double check you're e-stop. Make sure its reset.
    If you have a chip conveyor, it will also have an e-stop. (reset that one too)
    If you have a pallet changer, it will also have its own e-stop. (reset that one too)
    So you could have between 1 to 3 e-stops. ALL have to be reset.
    Good luck.
    Oct 2007
    South West Canada
    2,135
    439
    Quote Originally Posted by fivendime View Post
    So you weren't doing anything and the servo's just turned off?
    Dec 2006
    Utah
    79
    Quote Originally Posted by Dave Cross View Post
    Nothing. I just moved the head off the wood blocks and and paused for 10-15 seconds and then it shut off. I can go back and hit the contact for the coolant pump and go to the controller and clearthe errors. But with in a minute or so it will error out again while doing nothing.
    Maybe the wiring to the spindle cooler is wrong? All the wires were numbered with matching terminals. Minus the ground. Which is where I used the diagram to go to the correct terminal.
    Also it has 2 e-stops which are both out.
    Oct 2007
    South West Canada
    2,135
    439
    I think something in your procedure is not correct.
    If your E stop buttons are out,
    -Press reset, this should only get rid of alarm 330, 310 should clear for a second but come back on
    -Next hit the power on button on the control, this should energize the servos
    - turn the Mode switch to Jog, and turn on the zero return toggle switch
    -make sure all axis are about 4 inches away from their home positions, then push the + button for each axis and hold it until the home position light for that axis comes on
    Also as you face the machine, the large cabinet on the right hand side, open it up, look on the right wall, there is a gold plate with a toggle switch, I think it is labeled 1ts or 1t5, is it in position "normal" or "release"?
  11. #11
    Dec 2006
    Utah
    79
    It is shutting the servos off before I can get it homed. I will check the switch when I get home.
    Does anyone have this same spindle cooler they can take a pic of the way theirs is wired up?
    Thanks for all the replys!
  12. #12
    Dec 2007
    Ellensburg, WA.
    186
    32
    29
    Its been awhile since I've ran a matsurra, isn't there a reset button inside the spindle cooler? We had to remove the access cover, inside was a orange light, next to it was a reset button. I could be wrong, its been 15 plus years.
  13. #13
    Mar 2005
    3,676
    25
    68
    Could also be...
    X,Y,or Z driver boards.
    Our Matsuura just blew its X, and Y driver boards within 3 weeks.
    Then 2 weeks later. The main spindle drive board blew.
    But now its all back up and running...
    If its a driver board for an axis servo your looking at about 1,100-1,200$ to repair.
    If its the main spindle driver (and it probably isnt) Your looking at about 2,500$ to repair.
    Good luck man. We just went through this crap here and i wouldnt wish it on anyone.
    PS : Are your servos and drives Yaskawa ?
  14. #14
    Dec 2006
    Utah
    79
    Quote Originally Posted by Solar71 View Post
    Could also be...
    I hope it not the drives. I'm pretty sure they are the Yaskawa drives.
    Yes there is a reset button inside the cooler but it is not tripped.
  15. #15
    Dec 2007
    Ellensburg, WA.
    186
    32
    29
    Have you checked your phase to phase voltages? A rotary phase convertor will create a high voltage leg. Make sure it is within your machine specs.
  16. #16
    Dec 2006
    Utah
    79
    Quote Originally Posted by knc View Post
    Yes, I have checked that. It is well with in the % the manual I have calls for. I'm going off memory but they were with in 5%. The machine calls for >10% of a variance again off memory.
  17. #17
    Jan 2003
    Canada
    10,743
    4559
    2914
    And you got that generated leg on the slot where its least likely to be a problem for the control and such right?
  18. #18
    Mar 2005
    3,676
    25
    68
    Do yourself a favor. Goto your controler cabinet. The one with the axis drive boards, not the one with the main spindle drive board.
    Look at the X axis drive board. You should see a RED/White/Yellow Wires coming off the bottom.
    Thore are the power and signal wires that lead to your X asix servo.
    Power off the machine. Turn the breaker off too. (just to be safe)
    Then unscrew the 3 wire leads so they are no longer connected to the drive.
    Then see if the machine turns on ok...
    If it turns on then you know what the problem is. (the X axis drive or the X axis servo)
    If it does NOT turn on, then try the Y axis drive...
    Then again with the Z axis drive...
    Thats exactly what we did to diagnose our matsuura.
    Also, label the wires and draw a simple diagram on a paper so you know how to put the wires back.
    Once you put all the wires back, turn the machine on. MAKE SURE YOUR HAND IS HOVERING OVER THE E-STOP (just incase you get a runaway axis)
    Good luck man.
  19. #19
    Jan 2007
    Pinckney Mi.
    3,004
    4439
    787
    My mat. will do what sounds like your talking aboot,my problem is a drooping t/c arm,I climb up top with a ink pen and push a silanoid,t/c arm pulls up and alarm goes away,send her home and run the chit outa her.
    I am no techi,previos owner showed me.
    Gw
  20. #20
    Dec 2006
    Utah
    79
    Quote Originally Posted by Greg White View Post
    Gw
    Where is this solenoid located you are talking about.
    I also tried the switch where the axis drives are both location and still errors out after a minute. Also if you wait 5 miniutes you will be able to reset the alarm and it will run for another minute.
    I have not disconnected the axis drives yet. But can give that a try tonight.
