Help me outfit a 4th axis on my fadal
Results 1 to 6 of 6
    Jul 2008
    Milverton, Ontario, Canada
    391
    80
    139
    Default Help me outfit a 4th axis on my fadal
    I've tried emailing fadalcnc (havnt heard anything back, multiple times), kmac (referred me to fives, who appearantly now owns fadal name), and another more local company. Zero luck.
    I have a 98 AC 4020, not prewired.
    I have the DC rotary, an advanced motion controls 40acnh 20A DC (160Vmax) amp, and a 1010-5 control card with the v95.1k-5 ABnolim proms.
    Im pretty sure I need the 4th prewire bundle, the inhibit circuit, and the brake solenoid + wiring.
    I would assume the wiring bundle would be ordered for a DC machine (i need dc output for my rotary), as the power into the amp would be ac in either case.
    Not sure if im missing anything, but im lacking on schematics (im lacking the schemas for this machine).
    Would anyone be willing to hold my hand a bit through this?
    What should I order from fadalcnc to make this happen, and can ya'll offer a wiring schematic for me?
    Thanks guys!
    Feb 2010
    New York
    11
    5
    5
    Hi Stu,
    If I were you, I would call ITSCNC out of Chatsworth, CA. They have been fantastic for me, and I am sure they will get you fixed up in no time.
    It sounds like you have all the major components, and should be able to piece it together. Please let me know how it turns out, as I would love to do the same upgrade to my 4020 (DC machine with 88HS / -5 control).
    BTW, Did you get rid of your parts machine? If not, I am still interested.
    Good Luck!
    - Brian
    Jun 2006
    601
    15
    71
    What table are you going to use? I installed a troyke 9" table on my VMC40. It is a 1992 DC machine and I was already prewired for a 4th.
    I stole a table off of Ebay and it came with a Fanuc AC servo installed. I bought a DC motor from the classifieds here and then machined an adapter for the belt drive pulley. Plumbed the air solenoids and we are off to the races.
    I do love FadalCNC but I don't think you will get a good response via email. Calling is in order. It was nice for me to install a used table and save a bundle. The fadal is so easy to change ratio diameters on, there was very little to change in the parameters.
    Just my experience and FYI...
  4. Likes Bobw liked this post
    Jul 2008
    391
    80
    139
    Brian, thanks for the reminder. Totally forgot about ITS.
    Local buy bought the machine, and is going to put it to use. Pretty low tolerance work, so its perfect for him.
    Ill give ITS a shot tomorrow.
    I did find this http://www.fadalcnc.com/media/pdf/te...vo_Options.pdf on the fadal cnc site.
    I believe that covers all that I need...
    Jul 2008
    391
    80
    139
    G... I found a lightly used vh65 a couple years ago, along with the amp and board for $1000. thought that was a decent price, so long as it functions without TOO much rebuilding...
    May 2017
    Missouri
    38
    19
    we got our 4th axis vh-65, had over 10 years now. comes with like a 8-10 pin connector and a air line one to.
    they also installed another circuit board to. i would go for the fadal one, just to keep everything simple later.
